OmniFlop side 2
OmniFlop side 2
Postby Prime » Fri Sep 30, 2016 8:33 am
Is there a way to get OmniFlop to produce an ssd from side 2 of a disk? So if you had a floppy that was DFS formatted on drives 0/2 or 1/3, but you want to test / extract to two seperate ssd images?
I couldn't find a setting in the list of disk formats.
Re: OmniFlop side 2
Postby DutchAcorn » Fri Sep 30, 2016 8:47 am
Using DFS Imager you can split a double sided DSD in two single sided SSD's and combine two single sided SSD's into one double sided DSD.
