BBC BASIC for windows. Parallel port output
peepshow
Postby peepshow » Sat Aug 27, 2016 8:34 am
I have purchased, BBC BASIC for windows, which I am very pleased with.
But I wish to output from the printer port.
I have followed all the instructions in the help section......
Entered this into the program as instructed and put 'inpout32.dll' into the BBC BASIC for windows library all as
instructed.........
SYS "LoadLibrary", @lib$+"inpout32.dll" TO inpout32%
IF inpout32% = 0 ERROR 100, "Cannot load inpout32.dll"
SYS "GetProcAddress", inpout32%, "Inp32" TO `Inp32`
SYS "GetProcAddress", inpout32%, "Out32" TO `Out32`
But I am not sure how to use this line to output to the printer port or anything else I should do......
SYS `Out32`, portaddress%, portdata%
I am running XP on an old Dell D610 laptop
Can anyone help me please?
Many thanks.
Albert
"You are what was in your mother's genes
and what was in your father's jeans"
Re: BBC BASIC for windows. Parallel port output
Postby richardtoohey » Sat Aug 27, 2016 10:42 pm
Google for people using it from VB6.
e.g.
https://bytes.com/topic/visual-basic/an ... 32-dll-vb6
'Send the integer to the parallel port using inpout.dll (The "&H378" tells it that it is a data port and the integer tell it wich pins to turn on)
Out Val("&H378"), Val(D)
So you would need something like:
SYS `Out32`, &h378, <the data you want to send>
It will depend on what you are connecting to the printer port as to what you'd want to send.
This article explains a lot more about the parallel port:
https://theredblacktree.wordpress.com/2 ... ng-vb-net/
Postby jgharston » Sat Aug 27, 2016 11:47 pm
You should be able to do out%=OPENUP("LPT1:") just as on RISC OS you can do out%=OPENOUT("Printer:").
peepshow
Postby peepshow » Sun Aug 28, 2016 6:16 am
Thanks very much for quick replies.
I've never used SYS before so your replies are helpful.
I am trying to input 8 bity data from an external ADC
from a photo cell.
Regards.
Albert
Postby richardtoohey » Sun Aug 28, 2016 7:15 am
For input, it looks like you'd use the Inp32 function:
http://forums.codeguru.com/showthread.p ... pout32-dll
So I'd guess something like
SYS `Inp32`, &h378 TO your_data_variable%
I've not programmed Windows for a couple of decades nor used SYS ... &h378 needs to be replaced by your printer port address. Use at your own risk, YMMV, etc.
Might be easier exploring the LPT1 approach Jonathan suggested.
peepshow
Postby peepshow » Mon Aug 29, 2016 5:39 am
richardtoohey wrote:For input, it looks like you'd use the Inp32 function:
Thanks.
That "SYS `Inp32`, &h378 TO your_data_variable%" works OK now.
Being just an old fashioned BBC BASIC man, the 'TO' threw me, trying to puzzle out
where the NEXT was!! :)
