Batch 'compacting' a bunch of .ssd DFS disc images (on Win 10 x64)
Postby Arcadian » Mon Jun 13, 2016 3:18 am
Can anybody recommend a way of reducing the file size of multiple 200k .ssd files in one hit?
I thought that bbcim should be able to do this, but it doesn't seem to like wildcards (might be a Windows thing).
bbcim -min file.ssd works but bbcim -min *.ssd fails.
ABug Leicestershire (17-19 November 2017)
Re: Batch 'compacting' a bunch of .ssd DFS disc images (on Win 10 x64)
Postby danielj » Mon Jun 13, 2016 5:48 am
for %f in (.\*.ssd) do (bbcim -min %f)
(I think!)
Postby Arcadian » Mon Jun 13, 2016 3:33 pm
"f% was unexpected at this time."
simonm
Postby simonm » Mon Jun 13, 2016 3:49 pm
It's %f not f%.
If doing this in a batch file rather than command line, it's:
for %%f in (.\*.ssd) do (bbcim -min %%f)
Postby Arcadian » Mon Jun 13, 2016 8:34 pm
Doh!
Anyway that's worked a treat, thanks Daniel, Simon.
Wouter Scholten
Postby Wouter Scholten » Sun Apr 16, 2017 12:21 pm
Arcadian wrote:Can anybody recommend a way of reducing the file size of multiple 200k .ssd files in one hit?
In unix wildcard expansion is dealt with by the shell, so a utility doesn't see the *, it gets a list of files, unless there are no matches, in which case the * is sent as is...
So for me it would be superfluous to include any wildcard stuff unless I wanted to do something special. I might include it in a later version if I finish some code for this in my bbccom serial transfer software (for more abilities in the command interpreter) then I could add that code without much effort into bbcim.
I just made a small update to bbcim 1.0 to handle long filenames after all, as I ran into this problem on my PC directly accessing stuff in backup directories with long pathnames :) Although I normally use bbcim 1.2. Also added a little better message on using -ab instead of -a to force inclusion of files into a diskimage. (-a doesn't do this to enable you to do bbcim -a * so that non-BBC files don't get added). And I've included the postscript manual in doc/ ready made. Edit: Added pdf too.
See:
http://wouter.bbcmicro.net/bbc/bbc-pc-software.html
