Commodore 64
Lardo Boffin
Commodore 64
Postby Lardo Boffin » Sat Jul 15, 2017 9:11 am
I'm thinking of getting a C64 for my wife (mostly... 8) ) so she can play Aztec Challenge again. Anything I need to look out for when buying one? Capacitors that need changing / better video output etc.?
Many thanks!
Lardo
BBC Master
paradroid90
Re: Commodore 64
Postby paradroid90 » Sat Jul 15, 2017 9:17 am
Hi
For better Video output I would suggest a Lumafix which sits under the VIC II chip which increases the sharpness of the picture quality alot.
The other tip is to get a S Video Cable if your monitor can handle S Video signal.
Most common issue in my experience has been ram failure or logic chip failure. Peeps in the community have raised issues with the PLA's in some 64's, but this is not such a big issue as there are modern day subsitutes :-)
If you all looking to play the odd game, there are modern C2N replacements or a device called the SD2IEC.
Check out Lemon 64 for more like minded peeps, and as always google is your friend :-)
6502 Junkie :-)
Re: Commodore 64
Postby danielj » Sat Jul 15, 2017 9:27 am
Totally agree! lumafix + s-video is as good as the output from the c64 can get. Sd2iec is excellent, and I'd also recommend getting a jiffydos switcher, it speeds up loading hugely.
topcat96
Re: Commodore 64
Postby topcat96 » Sat Jul 15, 2017 11:27 am
If you are considering an sd2iec C64 setup then I would recommend an Epyx Fastload cartridge which puts loading speeds on par with JiffyDOS in a simple plug-in solution.
https://www.thefuturewas8bit.com/shop/c ... /eflr.html
iainjh
Re: Commodore 64
Postby iainjh » Sat Jul 15, 2017 12:13 pm
just agreeing on what everyone else said really; cheapest/ simplest is a standard c64, s-video cable and sd2iec. ive got a lumafix in mine and its nicer but not essential.
thefuturewas8bit.com make nice simple sd2iec boards you can fit internally later on.
might be worth pinging thecorfiot on here in case he's got one, he fitted jiffydos to mine and that gives access to a simple menu loader. Might save on some postage!
then you can pretend its her computer and you can play dropzone, flip&flop etc :)
Re: Commodore 64
Postby danielj » Sat Jul 15, 2017 12:49 pm
And actually, whilst you're at it, fitting a reset button is probably the other thing that's worth doing - and if you get the epyx cartridge that's built in. I put my own in and rolled my own JiffyDOS ROM/C64 ROM (you can buy the image: http://store.go4retro.com/jiffydos-64-k ... lay-image/). I got my SD2IEC from TheCorfiot.
Re: Commodore 64
Postby DutchAcorn » Sat Jul 15, 2017 1:24 pm
One thing to look out for is the SID sound chip. The C64 can appear to be working with a faulty sound chip and a replacement chip may cost you as much as a "new" C64 on eBay.
Re: Commodore 64
Postby MartinB » Sat Jul 15, 2017 1:35 pm
Unbelievably, I just simultaneously posted exactly the same thing as Paul! :shock: - SID chips are worth more than C64's on the open market these days (BeebSID hasn't helped!) and I do know of folk receiving C64's with either an empty space or where a fake dud has been swapped in with the trader selling the C64 as not fully tested.... [-X :roll:
Lardo Boffin
Re: Commodore 64
Postby Lardo Boffin » Sat Jul 15, 2017 2:50 pm
Thanks all. What is a reasonable guide price for one of these? Looking on eBay they seem to vary a lot.
BBC Master
topcat96
Re: Commodore 64
Postby topcat96 » Sat Jul 15, 2017 5:09 pm
Look for a C64c instead of the usual "breadbin" model. They are a lot cheaper to buy.
I personally wouldn't pay any more than £45 for a basic setup, then add on the cost of the sd2iec and jiffyDOS or Fastload.
javierglez
Re: Commodore 64
Postby javierglez » Sat Jul 15, 2017 5:58 pm
Instead of sd2iec + fastloader I'd go for the 1541 Ultimate 2+. It ensures 1541 compatibility which is important for demos and sd2iec certainly doesn't. I don't know if the fastloader covers for it but I doubt it. Besides the ultimate provides stereosid emulation and ram expansion and partial support for networking. If you get a real 1541 bundled with the 64 then sd2iec is good enough though
Re: Commodore 64
Postby danielj » Sat Jul 15, 2017 6:06 pm
Although it is about £100 more expensive :?
javierglez
Re: Commodore 64
Postby javierglez » Sat Jul 15, 2017 6:24 pm
I think the actual difference is like 90€, plus you spare the fastloader. sd2iec loads cracked games, and nothing else.
topcat96
Re: Commodore 64
Postby topcat96 » Sat Jul 15, 2017 6:38 pm
javierglez wrote:sd2iec loads cracked games, and nothing else.
Speaking from experience, my sd2iec has handled any D64, D81, D71, M2I images as well as PRG's that I care to throw at it. Your comment about it loading cracked games only is incorrect. The only thing an sd2iec does not do well is True Drive Emulation, but then again neither did the real 1541 disk drive 100% of the time.
javierglez
Re: Commodore 64
Postby javierglez » Sat Jul 15, 2017 7:06 pm
The Ultimate emulates 1541 drive which has its own 6502, ram & rom. The sd2iec originally was just another serial bus compatible device. They've been upgrading the firmware, and fixing lots of disk images *games-no demos*, to improve compatibility.
topcat96
Re: Commodore 64
Postby topcat96 » Sat Jul 15, 2017 7:12 pm
The OP only wants a setup for his wife (and him) for games usage ... an Ultimate 1541 is a bit of an overkill in that regard. :D
javierglez
Re: Commodore 64
Postby javierglez » Sat Jul 15, 2017 7:28 pm
Newly built readers is a hot topic, I think there are a few more choices, Easyflash, Chameleon.
Recently bought a yellowed Master + Datacenter & 3,5"dd from Retroclinic. Came upon a couple of messages here in this forum and then decided.
javierglez
Re: Commodore 64
Postby javierglez » Sat Jul 15, 2017 8:14 pm
A hardware kind of guy will certainly enjoy more replacing kernel rom with jiffydos (usually unsocketed), saudering the internal sd2iec and a reset line and then modding the case for those.
Lardo Boffin
Re: Commodore 64
Postby Lardo Boffin » Sat Jul 15, 2017 8:27 pm
Im definitely looking to keep costs and effort to a minimum at this stage - I don't know how much usage this will get. If it turns out to be a lot I will doubtless improve things. I do like messing with hardware but know nothing about C64s yet as I never had one.
At this stage my priorities are:-
1) Decent video output
2) Being able to load games I can download (not too fussed about speed, so long as it is faster than cassette!)
I would of course buy a copy of Aztec Challenge and a cassette player but it seems a little rare.
Lardo
BBC Master
Re: Commodore 64
Postby danielj » Sat Jul 15, 2017 9:52 pm
SD2IEC and away you go then. Or a datasette: http://www.ebay.co.uk/itm/122582139692
But then you have to mess about with tapes...
chinnyhill10
Re: Commodore 64
Postby chinnyhill10 » Mon Jul 17, 2017 7:19 am
topcat96 wrote:The OP only wants a setup for his wife (and him) for games usage ... an Ultimate 1541 is a bit of an overkill in that regard. :D
Indeed. I own an Ultimate 2 and an SD2IEC
While the Ultimate 2 is lovely, it is very expensive and does stuff the average games player won't care less about. The SD2IEC is a hundred quid less and does most stuff the average games player wants. Disk swapping involves button pressing but that aside it's pain free.
One gotcha if you are planning to use S-Video, the 64's output might approximate S-Video but is actually intended for Commodore monitors. So you may find it doesn't work on all devices or looks rubbish. For ChinnyVision early attempts at capturing from the higher quality signal failed until I found something that was happy with the slightly out of spec signal.
Re: Commodore 64
Postby danielj » Mon Jul 17, 2017 7:28 am
@Chinny - did you try the lumafix board? it sorted out the picture on all my LCD sets?
chinnyhill10
Re: Commodore 64
Postby chinnyhill10 » Mon Jul 17, 2017 10:58 pm
danielj wrote:@Chinny - did you try the lumafix board? it sorted out the picture on all my LCD sets?
No. It's on the list of potential things to do. But my S-Video capture is clean so that's the main thing.
Lardo Boffin
Re: Commodore 64
Postby Lardo Boffin » Thu Aug 03, 2017 2:14 pm
Thanks for the advice all and thanks for the hardware (topcat96)! The picture is just using RGB at the moment and to be honest is pretty good. Would a lumafix make any difference to this or does it just affect s-video?
I managed to find a copy of Aztec Challenge on cassette - admittedly a reissue not the first release but beggars can't be choosers and all that.
This game is as hard as nails! Also I may be running out of space on my retro desk...
Lardo
BBC Master
Re: Commodore 64
Postby danielj » Thu Aug 03, 2017 3:55 pm
I thought the c64 only did s-video, or composite?
Lardo Boffin
Re: Commodore 64
Postby Lardo Boffin » Thu Aug 03, 2017 5:33 pm
Sorry - not RGB. Bit distracted when posting!
It's connected to a SCART socket.
BBC Master
Re: Commodore 64
Postby 1024MAK » Thu Aug 03, 2017 7:43 pm
Lardo Boffin wrote:Sorry - not RGB. Bit distracted when posting!
Err, SCART is "just a connector". SCART can carry composite video OR RGB OR S-Video. If you look at your TVs settings, it should tell you if you are using composite or S-Video. If it does not say S-Video, then it is defaulting to composite video. You can also tell by looking inside the SCART plug, or the DIN plug and reporting here on which pins are connected (or looking it up). You still need to see what signal the TV has been set to receive.
I use S-Video with my C64 and C128 machines, as the separation of the colour encoded signal from the luminance offers a better quality picture than composite video.
Commie_User
Re: Commodore 64
Postby Commie_User » Thu Aug 10, 2017 11:46 am
topcat96 wrote:Look for a C64c instead of the usual "breadbin" model. They are a lot cheaper to buy.
A breadbin may be a good buy if affordable and peak condition because some games look better with it and the sample channel is the right volume. You'll know when running Turbo Out Run. Its music is one of the towering heights of 64 music.
Also, use a multimeter to check the power supply output. Knackered BBC PSUs just go out, while Commie ones overload the board with voltages which fry the peripherals.
Commie_User
Re: Commodore 64
Postby Commie_User » Thu Aug 10, 2017 11:49 am
Lardo Boffin wrote:Thanks for the advice all and thanks for the hardware (topcat96)!
Lardo
Congratulations on your upgrade to the executive class of computer. A wise decision. Just don't use the BASIC or expect to do too many intermediate projects on it...
Re: Commodore 64
Postby 1024MAK » Thu Aug 10, 2017 12:52 pm
I thought the C128 in a metal case with built in FDD and separate keyboard was the height of Commodore 8 bit (the C128DCR) :P
