Having a really bad three weeks!
Postby daveejhitchins » Tue Jul 11, 2017 7:06 pm
It was a dark, moonlit night . . . When my RepRap Huxley 3D printer started to fall apart - The printing became erratic - I traced it to a crack in one of the X support bearing tubes. When I looked further I noticed that some of the other parts had cracks in them. All the parts we the supplied printed pieces . . . . Then along came DanielJ and offered to reprint the affected parts =D> Many thanks :D
In the meantime, realising I'm way behind in producing 3D printed MGC case, I ordered a replacement in the form of a Kodama Trinus - Built like a brick outhouse 8) - It duly arrived this Monday morning. Build went very smoothly - Set-up went OK - Then I noticed that one of the hot-end fans wasn't working . . . It has two of them in series?? The outer one seemed dead. Checked with a 9V battery - Fan OK - Checked Voltage on the connector pins -
it appeared very erratic. So, I thought, get the 'scope out and have a look. But first a visual check. There seemed to be a driver (transistor/FET?) and, probably, driven directly from the processor. All the soldering looked fine. Setting up the 'scope, I connected to channel 4 (nearest to the printer, the way I had it) nothing :? Spent a while checking other pins - after a while it dawned on me that channel 4 wasn't working. Don't think I've used it before - RIGOL 4 month old. Fortunately purchased from the UK main dealer.
Well, that's my 3 pieces - everything should go smoothly from now on [-o<
vanpeebles
Re: Having a really bad three weeks!
Postby vanpeebles » Fri Jul 14, 2017 6:43 am
Build a heavy duty steam powered one :D
Postby tricky » Fri Jul 14, 2017 7:02 am
If start with cast iron as steel can be tricky at home ;)
Postby 1024MAK » Fri Jul 14, 2017 4:02 pm
Bodge it using Meccano :lol:
Postby jgharston » Fri Jul 14, 2017 6:25 pm
1024MAK wrote:Bodge it using Meccano :lol:
Indeed! :)
Return to “off-topic”
