I'm currently working on a version of AstroBlaster for the BBC and was hoping for a bit of feedback before it gets too late. For programming discussion, please use the thread at RetroSoftware: http://www.retrosoftware.co.uk/forum/viewtopic.php?f=19&t=912&p=6805#p6805 I'm probably going to leave running out of fuel as loosing a life, not game over as in the arcades. Speech is out unless there is an extended (sw ram/B+/master etc) version. I haven't looked in to the speech ROM expansion, but that may be an option! I will add joystick support, probably same as Carnival(e). I should be able to get the asteroids in and maybe a few secret bonuses. I'm going to make the rocket levels single pass and tidy the formations that are currently just a flat overlapping row. What sort of scores are people getting, I can usually get ~20k using one warp per sector (ends with fireball).
keys Z,X left, right. RETURN fire, SHIFT warp EDIT: Tweaked .ssd to not upset B-Em so much
File comment: Tweaked to not upset B-Em so much AstroBlaster.zip [7.69 KiB]
Downloaded 7 times
Last edited by tricky on Sun Aug 31, 2014 1:19 pm, edited 1 time in total. _________________
Joined: Mon Jan 08, 2007 7:38 am Posts: 1068 Location: Derby, UK
Terrific!!
I wasn't familiar with the original, but having looked at screenshots I can't believe how faithful your version is. I've played it a bit, got to Sector 3 quite easily - is the warp feature part of the original game or is it something to help skip levels for demo purposes?
My kids played it quite a bit, and they weren't able to break it!
The arcade version has one warp per sector, which ends after the asteroid storm (currently one fireball) and then docking with the refuel ship. If you run out of fuel (time) or fail to refuel, it's game over. I will be reducing the warp to once per sector, but once per wave is useful for testing. I don't have enough memory for the docking seq, but I don't think it will make the game less fun. I am planning on keeping the refuel, rest the warp and cool down if you die, but to compensate I am planning on keeping the whole wave respawns if you die - and it's less code
The original is 60Hz, and I think I have all the movement identical, so it was actually 20% faster in the arcades I make the warp last for the same time as the 60Hz version, so you can actually do less, but the arcade version always felt too long to me. PS It is optional to activate warp
Thanks guys, I guess that as it wasn't very popular in the arcades there aren't many memories to not live up to
It may have not been popular because it was so hard - there were at least three release, with each getting easier until the last was just very very very hard.
Not too much practicing, I was hoping to get this in the next hi-score challenge
You could always take the cheap option and use the Acorn speech upgrade for the spoken messages.
That reminds me: I must rebuild BeebEm for my system since I believe it emulates the speech chip, and it would be interesting to hear what it sounds like.
Thanks, I had a quick look last night, looks like I will have to do some 6502 disassembling and playing to assemble the words from speech fragments.
Maybe I can find a text to speech program for the beeb+speech chip and save some time.
It is a shame that this wasn't a more popular upgrade as having 32KB extra RAM, that can be used as a ROM would have been good and many games could have uploaded custom data to play extra/different sounds.
Sprow produced an example PHROM image that contained digitised speech - I believe he put the details on the BBC Micro Mailing list but I can't find the post at the moment. (Think he ran a competition offering a free speech upgrade for anyone who could figure out how to do it!)
Might be worth trying to dig out the post in case there are any useful details?
The Sprow upgrade is more flexible than the original as replacement PHROM images can be soft-loaded on the fly. I guess this would work well for Astroblaster but suspect that the modern version is even less common than the Acorn original?
I think the Beebs that failed to sell in the USA were all fitted with the upgrade so there could have been quite a few out there at one point. Can anyone confirm this?
"This machine was designed for the American Market, and unfortunately wasn't a big success over there, like it was here. It is effectively a Model B with a redesigned motherboard, and comes as standard with Disc filing system, Econet networking, Speech and VIEW word processor."
Joined: Mon Apr 18, 2011 5:46 pm Posts: 2358 Location: Looking forward to summer in Somerset, UK...
I have a issue 3 Beeb (I think) that has the Acorn speech system fitted. I have no other Beebs that have this upgrade. All my Acorn machines were bought second hand.
IIRC, the PHROM is a ROM that contains speech data.
Does the USA Beeb have the Kenneth Kendall PHROM or the one with the American accent?
According to the description for Mark's American Beeb, linked-to above ^^, it's the one with the American accent.
Thanks Dave - that's what I suspected. So not much use if you're looking to do something based on the UK version.
tricky wrote:
I thought that you could upload to the original, but may be confusing it with the upgrade.
Think you can drive the speech processor by using the CPU to load data from RAM but that's not much good if you're tight on memory and don't want to use up precious cycles. Sprow's version allows you to pre-load the PHROM which is much better.
I don't have space for docking with the mother ship without losing more of the dashboard, and am not feeling too well, so the compromise for now is to turn all the asteroids into fireballs and refuel that way.
EDIT: Lockup fixed, new .ssd added
I am still planning on adding joystick support.
If anyone has any programming suggestions, please post them over at RetroSoftware, for gameplay, or comments about the game, here is fine.
EDIT: .ssd updated with one that doesn't hang
File comment: Z,X, SHIFT and RETURN AstroBlast.zip [7.92 KiB]
Downloaded 5 times
Last edited by tricky on Sat Sep 13, 2014 9:52 pm, edited 2 times in total. _________________
You cannot post new topics in this forum You cannot reply to topics in this forum You cannot edit your posts in this forum You cannot delete your posts in this forum You cannot post attachments in this forum
