Dave H
Please contact me next week, M Sadler . . .
daveejhitchins wrote:Plenty left, I managed to get hold of 80 FlashROMs so I ordered enough parts for them all. I think I'm up to 30+ , so far![]()
roland wrote:I have build a RGB to SCART cable today and tested mine. It works great! Good to see those old games again.
Unfortunately my Elk crashes after playing games for a while and I have unplug the power about five minutes and then it works again for about 10 minutes. But that's something for another topic - after I have reseated the ULA. IIRC it's an UK Electron. The German Electrons works fine with the MGC so the cartridge is not the problem.
roland wrote:Great work David and others that have worked on it.
roland wrote:BTW is there also a search option for finding games?
davidb wrote:If it's a UK Electron then it's probably just being lazy.Actually, I wonder if it might not be a different type of ULA to the ones in the German Electrons - perhaps those were supplied with later variants that were more reliable.
sadken wrote:For some reason i can't reply to your PM :/
danielj wrote:That's because you didn't have 25 posts. You should be able to PM now though!
Hedge wrote:I was wondering would it be easy to emulate this particular device in B-EM
so more people can play with the code and make their own compilations?
Not the same as plugging one into a real elk or master of course, but for future projects
using the hardware, ( Like that giant 4mb game! ) it might be an idea.
it's a little more complicated than that as any ROM you want to use has to appear in the menu. I've created a spreadsheet for that purpose. A csv of the spreadsheet is then turned into a whole MGC contents file plus a set of 64K blocks. If you're just changing one game/application/utility then, as a minimum, you'll need to replace two (maybe just one if the game is in the same block as the index) blocks - one of which will contain the new index.sadken wrote:That's awesome![]()
Can you upload any rom to the cart?
sadken wrote:Can you upload any rom to the cart?
Sorry, that's going to be a while! I'm over half way through the first batch of boards, thoughvanpeebles wrote:Any word on a Master version yet?
