Albert's House (Game wanted) BBC Micro/Master
Albert'sHouse
Postby Albert'sHouse » Fri Jun 12, 2009 9:03 pm
I'm looking for information on a BBC Micro or Master game called Albert's House where you have to save a mouse called Albert from a cat. It was a children's game from the 80s or 90s that I played at school and I'm looking to get hold of a copy to play again. It has been released in an updated format for the PC. If anyone could provide me with any information on the game I'd be very grateful.
iamaran
Re: Albert's House (Game wanted) BBC Micro/Master
Postby iamaran » Sat Jun 13, 2009 9:59 am
Still for sale here (albeit for Windows):
http://www.resourcekt.co.uk/albert/product.htm
Albert'sHouse
Postby Albert'sHouse » Sat Jun 13, 2009 7:17 pm
I already have the PC version. I'm looking for the Micro/Master version.
Thank you anyway.
Postby Arcadian » Sat Jun 13, 2009 11:41 pm
Here's the AH disc image that Andrew Skipper (username: vbbc) sent me two years ago (oops) ... haven't tested it but hopefully you'll get some mileage out of it! :)
Albert's House.zip
(57.43 KiB) Downloaded 368 times
Albert'sHouse
Postby Albert'sHouse » Sat Jun 13, 2009 11:51 pm
Thank you so much.
This trounces the PC version.
You've made the child in me very happy.
Last edited by Albert'sHouse on Sun Jun 14, 2009 12:13 am, edited 1 time in total.
Albert'sHouse
What are the controls?
Edit:
Found the controls.
Arrow keys and return.
Last edited by Albert'sHouse on Sun Jun 14, 2009 12:11 am, edited 1 time in total.
Albert'sHouse
Postby Albert'sHouse » Sat Jun 13, 2009 11:55 pm
This game brings back many childhood memories.
Albert'sHouse
Postby Albert'sHouse » Sat Jun 13, 2009 11:57 pm
Game seems to crash part way in.
Might just be the emulator I'm using though.
Albert'sHouse
Postby Albert'sHouse » Sun Jun 14, 2009 12:03 am
Working now. Must just have been an issue with my emulator.
guesser
Postby guesser » Sun Jun 14, 2009 10:47 am
wow, it's a good few years since I've played this!
we used to have it in year 3 and 4 of primary school :)
vaniladragon
Postby vaniladragon » Wed Apr 12, 2017 1:01 pm
I've been looking for this game for ages. I thought it was called Cat and Mouse or something but I'm so happy I found it.
I know this is a very old board but I'm having problems with the game where it crashes after 4 or 5 screens (specifically moving away from the stairs)
I've tried two different emulators and get the same result. Can anyone help?
Postby lurkio » Wed Apr 12, 2017 1:53 pm
vaniladragon wrote:I know this is a very old board but I'm having problems with the game where it crashes after 4 or 5 screens (specifically moving away from the stairs). I've tried two different emulators and get the same result. Can anyone help?
If you're using the .ADL disc image, then you'll have to go to the Hardware menu in BeebEm, select "BBC Master 128", load the disc, and then type in the command *ADFS before booting the disc with Shift-Break.
If you're using the .SSD disc image, then you'll need to make sure that Watford Electronics DFS 1.44 is installed. The Watford DFS can store up to 62 files on a single .SSD (which is more than Acorn's standard DFS). See the Hardware menu in BeebEm and try switching to "Model B Plus" or to "Model B Plus Integra-B" to see if the Watford DFS is installed by default for one of those emulated machines. If you can't find a machine with a pre-installed Watford DFS, then you'll have to edit the ROM configuration for the Model B or the Model B Plus (or the Model B Plus Integra-B) to install the Watford DFS ROM yourself.
:idea:
billcarr2005
Postby billcarr2005 » Wed Apr 12, 2017 6:13 pm
This image was created from an original disk I have.
I haven't compared the contents of the disks.
Only has 31 files, so no need to use Watford DFS.
Don't know if it crashes later on...
Albert's House.zip
Albert's House
(28.2 KiB) Downloaded 43 times
vaniladragon
Postby vaniladragon » Thu Apr 13, 2017 7:24 am
Thanks Lurkio
Changing the BeebEm to Model B Plus Integra-B made everything work great. So many great memories came back
