Repton 2 - Cassette Version - LOCKED
Trapper
Post by Trapper » Wed Mar 28, 2018 7:00 pm
Hello,
I've downloaded the WAV for Repton 2 and have recorded it to tape. My method for recording this way is sound as I've made several tapes already with no problem at all.
With Repton 2 the tape will load up to "REPTON 2 02 0229" and then errors with the message "Locked" and the cassette motor turns off quite hard.
At first I thought it was a bad recording, but it keeps happening. Is this some form of early copy protection?!
billcarr2005
Re: Repton 2 - Cassette Version - LOCKED
Post by billcarr2005 » Wed Mar 28, 2018 7:15 pm
Are you attempting to *LOAD the file?
"Locked" means it's locked from anything except *RUN (or CHAIN"")
Trapper
Post by Trapper » Wed Mar 28, 2018 7:20 pm
No I've been doing a:
*TAPE
CHAIN ""
vanekp
Post by vanekp » Wed Mar 28, 2018 7:29 pm
as long as you are CH."REPTON2" file it should load as that is a basic program loader for the rest, but if its having a problem with the 1st block and it skips it will tries to load the "?" file then it going to give a locked message as that file is locked on the tape.
Peter.
Trapper
Post by Trapper » Wed Mar 28, 2018 7:38 pm
Ah! That did it!
Cheers. I was CHAIN "" rather than CHAIN "REPTON2" which is now loading. The wife will be happy!
Any reason why CHAIN "" failed? I haven't had an error on dozens of tapes I've loaded that way!
vanekp
Post by vanekp » Wed Mar 28, 2018 8:09 pm
should have worked with CH."" as well must be something a bit dogie with the 1st bit of your tape.
I have my wav files on my smart phone tablet or ipod and play then from there 100% loading every time :)
Tapes are a thing of the past :)
Peter.
