fix for elixir !!
duikkie
fix for elixir !!
Postby duikkie » Fri Sep 01, 2017 12:52 pm
i am looking for people who things like playing games
because i never play , i only fix things :)
download elixtest file
*run elixir2
it is not finisch yet because the intro , instuctions en maybe keychange is in file 1
what i have to make.
but is my fix for mmc/sd card good and do the game play as normal ??
standaard keys are z x * ?
duikkie
Re: testgamers for elixir !!
Postby duikkie » Fri Sep 01, 2017 1:02 pm
fixing picture :)
duikkie
Postby duikkie » Fri Sep 01, 2017 4:52 pm
errors or no players at home yet :)
Postby danielj » Fri Sep 01, 2017 5:00 pm
If you press RETURN on the status screen on beebem, the font's corrupted. Not sure if this is the same on a real beeb I'm afraid :(
billcarr2005
Postby billcarr2005 » Fri Sep 01, 2017 6:37 pm
what is the issue regarding mmc/sd card that requires (major?) fixing?
duikkie
Postby duikkie » Fri Sep 01, 2017 7:47 pm
the same problems with *disc and so on
but this program does it in an other way . it ask the *dir and drive store it , recall the *disc. and the d00-1100 thing
it does a swap with &d00 : use overlay programming loading 2b00 +870 in over the program that is not usefull anymore like the instructions and key change with starts at &31bc till &337b , swap area &d00 with 337b ..347b.
and the 400-d00 was loading from elixir1 program
so the startup routine was lifted from 31cb mostly moved to 6500 everything is downloaded to its place and elix3 is already at 2b00 +870 : the mode switch is at 3a0 now then calling &42xx to start
that all :)
billcarr2005 wrote:what is the issue regarding mmc/sd card that requires (major?) fixing?
duikkie
Postby duikkie » Fri Sep 01, 2017 7:50 pm
when do you get status screen ?? is this at the end of game or when you are x died ?
danielj wrote:If you press RETURN on the status screen on beebem, the font's corrupted. Not sure if this is the same on a real beeb I'm afraid :(
Postby danielj » Fri Sep 01, 2017 7:53 pm
Just when you're playing, sorry, press RETURN and it pops up a status screen?
duikkie
Postby duikkie » Sat Sep 02, 2017 7:24 am
i did not know the game has a status screen , but it is not good , in disc version on real disc it is normaal
have to look in files where the status screen is coming from and what i have done or forgot to do :)
further on playing all oke ??
danielj wrote:Just when you're playing, sorry, press RETURN and it pops up a status screen?
duikkie
Postby duikkie » Sat Sep 02, 2017 10:04 am
text is there but not clear about all the sh*t around
BBC, Electron:
&0366 Teletext output cursor character
&0367 Font explosion flags, b1=224-255 in RAM, b7=32-63 in RAM
&0368 Font location, characters 32-63
&0369 Font location, characters 64-95
&036A Font location, characters 96-127
&036B Font location, characters 128-159
&036C Font location, characters 160-191
&036D Font location, characters 192-223
&036E Font location, characters 224-225
&036F-&037E Palette for colours 0 to 15
&037F Unused - used by some Shadow RAM systems
duikkie
Postby duikkie » Sat Sep 02, 2017 10:13 am
explosion=bomb from IS ??? :) ??
we have lda #&18 or #&38
sta &367
lda #&2b:sta &369 meaning ??
Postby oss003 » Sat Sep 02, 2017 10:16 am
B-Em, BBC-B with 8271 FDC PAGE=1900
duikkie
Postby duikkie » Sat Sep 02, 2017 10:17 am
it is the area &367--36f that is wrong ??
oss003 wrote:B-Em, BBC-B with 8271 FDC PAGE=1900
Postby oss003 » Sat Sep 02, 2017 10:35 am
Looks like the addresses are overwritten:
duikkie
Postby duikkie » Sat Sep 02, 2017 10:56 am
yes that is because elix2 at &31CB is doing , but somehow it is wrong when the game is playing ??
but i do not understand sh*t around this locations :(
oss003 wrote:Looks like the addresses are overwritten:
Michael Brown
Postby Michael Brown » Sat Sep 02, 2017 11:19 am
This new version also has the corruption on BeebEm4.14
The original disc version copied onto my disc034 works fine on both BeebEm and B-em, so the problem must be either with the ELIXIR2 file on the test disc or is something missing from one of the earlier files?
Mick.
Postby oss003 » Sat Sep 02, 2017 11:24 am
Duikkie,
I think I found the problem,the problem is writing &2B to &036A at address &6538.
If I change this value back to &05, as in the original game, the font is ok.
Looking at the code, I think it's a typing failure, STA &036A should be STX &036A.
Your notes were ok ...... :wink:
duikkie
Postby duikkie » Sat Sep 02, 2017 11:43 am
thanks will update and upload :) one byte missing 8d <>8e :)
duikkie
Postby duikkie » Sat Sep 02, 2017 11:49 am
update fixing own bug :)
ELIXTEST.zip
(14.36 KiB) Downloaded 12 times
duikkie
Postby duikkie » Sun Sep 03, 2017 4:10 pm
almost there :) update for testing
*run elixir1 =intro and key switch if you want
it runs elixir2 (can run on its own if not after elixir1 then standaard keys are loaded , if &3bx after /elixir2 is not EA)
to do
some begin screen from software house and elixir screen before intro :)
this i think i call elixir :shock: :^o
ELIXTEST0903.zip
(17.53 KiB) Downloaded 9 times
Postby CMcDougall » Mon Sep 04, 2017 6:03 pm
it works fine with normal floppy discs, works fine also with SuperMMC 0.90,
but does not like the MMFS due to Dave's (as per) good explanation:
viewtopic.php?f=3&t=10621&start=660#p178172
Just had a go on my MMFS 1.36 with the latest 'ELIXTEST0903' and works :D
Many thanks Duikkie!!! =D> =D> =D>
duikkie
ELIXIR 99,9% GOOD
Postby duikkie » Fri Sep 08, 2017 3:52 pm
a few bugs left but i think most of the players don't mind [-o<
if the game starts it overlay the mode 5 screen for downloading the intro , and also if you start to play
i can fix this by everytime switching of the screen or goto mode 7 . but nobody is perfect , so i all it finisched
ELIXIRFIX.zip
(20.79 KiB) Downloaded 10 times
Users browsing this forum: Bing [Bot] and 5 guests
