mmbeeb file error with Qwak
Heydave88
Postby Heydave88 » Tue Jul 18, 2017 10:15 pm
Wasn't sure if this was the right place, but was wondering if anybody could help.
I've just installed an MMC SD card interface to my model B and so far it's working great (supplied by the great Tricky on this forum)! Only issue is that one game - Qwak! - gets an error and doesn't run.
I was using a pre-compiled library of Beeb games like the MMB file here: viewtopic.php?f=3&t=8176#p87705
But for whatever reason when running Qwak! I receive this error:
"BASIC
>PA.=&1900
>CH."QWAK!"
Bad command at line 20
>_"
I've had a look at the mmbeeb website (here: https://swhs.home.xs4all.nl/bbc/mmbeeb/ ) to see if I could somehow recompile the mmb file with a new copy of Qwak! but...well I got stuck pretty quickly after downloading the "games menu" utility. Do I need to have Microsoft access 2000 on my computer and download each of the .ssds separately? Alternatively, how could I upload the Qwak! .ssd image onto my SD card?
Thanks for any help with this!!
billcarr2005
Re: mmbeeb file error with Qwak
Postby billcarr2005 » Tue Jul 18, 2017 10:27 pm
Might be helpful to know what (bad) command is being issued on line 20 :)
Heydave88
Postby Heydave88 » Tue Jul 18, 2017 10:49 pm
billcarr2005 wrote:Might be helpful to know what (bad) command is being issued on line 20 :)
Any idea how I can find this out? I just launch the menu using shift + break, then select Qwak! and press return to launch it, when it shows the above message. Unfortunately I'm not sure how to get any more info out of it... Sorry I'm pretty useless, not sure what I'm doing #-o
I've tried downloading and launching the mmbimager.exe and dfsimager.exe found here: https://swhs.home.xs4all.nl/bbc/mmbeeb/windows.html but both of them fail to run on my windows 10 laptop or desktop...
Thanks for any help!!
Postby CMcDougall » Tue Jul 18, 2017 10:56 pm
it works on MMFS1.35 no problem & SuperMMC0.91
looking at line 20, it issues a *DISC
so, put 20REMdisc
RUN #-o
Heydave88
Postby Heydave88 » Tue Jul 18, 2017 11:07 pm
CMcDougall wrote:it works on MMFS1.35 no problem & SuperMMC0.91
so, put 20REMdisc
RUN #-o
Thank you so so much!! Can't tell you how good it is to get Qwak! running on the machine after struggling with tapes for so long!!!
Might be a bit beyond my abilities, but is there any way to alter the .BBM file so it does these commands automatically?
Thanks again!
Postby DutchAcorn » Wed Jul 19, 2017 4:52 am
Heydave88 wrote:Thank you so so much!! Can't tell you how good it is to get Qwak! running on the machine after struggling with tapes for so long!!!
Thanks again!
You should be able to do that on your BBC entering the following commands:
*DIN 223
*DOP U
LOAD"QWAK!"
20
SAVE"QWAK!"
*DOP P
That should fix it permanently.
Some explanation:
*DIN 223 selects the virtual floppy containing QWAK!
*DOP U unprotects the currently selected virtual floppy so you can write to it
LOAD loads QWAK! without running it
20 Removes line 20, so the *DISC command won't get executed
SAVE saves QWAK! back to the virtual floppy
*DOP P puts the protection back to the virtual floppy so it is read-only again.
duikkie
Postby duikkie » Wed Jul 19, 2017 9:31 am
oke i know but is there the normal tape file from qwak! , because [-X
we have a basic program qwak! with *load lsqwak from &5800 to &7900 the screen , if not terrible enough
we load a machine code program qwak1 over the screen at &7000 holding a downloader for file DATA at &1400 with 4800 bytes
so &1400+&4800=&5C00 again over the screen
Qwak1 machine code program is to long at &7058 we have some downloader again ???
would it not be nice to have 1 file (maybe 2) to run QWAK :shock: [-X #-o [-o< =P~
duikkie
Postby duikkie » Wed Jul 19, 2017 9:48 am
what is this ( for econet users ??)
?&224=?(&24+!&ffb7)
Heydave88
Postby Heydave88 » Wed Jul 19, 2017 10:50 am
DutchAcorn wrote:You should be able to do that on your BBC entering the following commands:
*DIN 223
*DOP U
LOAD"QWAK!"
20
SAVE"QWAK!"
*DOP P
Thank you so much for this!!! For some reason the *DOP U and *DOP P commands to unprotect and reprotect the disc wouldn't work for me (returned Bad command) but I was able to get around this by inserting the SD card in my computer, unprotecting using mmbimager.exe, then editing in the BBC and re-protecting in the computer afterwards.
Runs fine every time now! Thank you again!!
duikkie
Postby duikkie » Wed Jul 19, 2017 11:23 am
Use *dunlock 223 and dlock 223 :)
*DIN 223
*DOP U
LOAD"QWAK!"
20
SAVE"QWAK!"
*DOP P
duikkie
Postby duikkie » Thu Jul 20, 2017 12:07 pm
because i could not leave it
almost perfect :) 1 file Qwak
it changes from mode7 to mode 5 without data lost
old data file Reconsidered , basicfiles in m-code
it is for beeb bbc. i don't think electron has the same mode codes switches
to run :
*run qwak (because it is all m-code now)
fixqwak.zip
(23.96 KiB) Downloaded 13 times
duikkie
Postby duikkie » Thu Jul 20, 2017 6:46 pm
sadly it only works with beeb bbc mos acorn 1.2
it is the routine at &cb1d that is different in other mos systems
duikkie wrote:because i could not leave it
to run :
duikkie
Postby duikkie » Fri Jul 21, 2017 9:56 am
fix number 2
b.bcqwak! is the 1 file only for bbc os1.2
qwak! and qwak1 two file version for more machines
still not good for electron ??
fixqwak2.zip
(35.01 KiB) Downloaded 11 times
