BBC keyscan routine
BBC keyscan routine
Postby oss003 » Wed May 31, 2017 5:47 pm
Hi guys,
can somebody please explain what the keycodes are in this keyscan routine because I can't find any documentation about this:
; Key check routine
; A = keycode to check, on return A= #80 is pressed
L0C83:      sei
            ldx #$03               ; Stop autoscan
            stx LFE40
            ldx #$7F               ; PA0-6 output
            stx LFE43
            sta LFE4F              ; Key to read
            lda LFE4F              ; #80 if key pressed
            php
            ldx #$0B
            stx LFE40
            plp
            cli
            rts
Thanks.....
Re: BBC keyscan routine
Postby hoglet » Wed May 31, 2017 5:53 pm
Probably internal key numbers:
http://stardot.org.uk/mirrors/www.bbcdo ... f#page=142
That just a guess....
Postby oss003 » Wed May 31, 2017 6:01 pm
In the game these keycodes are checked: #B7, #C2, #C7, #C8, #C9, #E1, #E8 but they don't correspont with the User Guide.
Postby hoglet » Wed May 31, 2017 6:07 pm
OK, I've engaged my brain now.
The code is directly driving the BBC keyboard matrix:
http://mdfs.net/Info/Comp/BBC/Circuits/BBC/bbckbd.gif
So #B7 (1-011-0111) is checking row 3, column 7 which looks like "P" to me.
This is actually the internal key number, but with bit 7 set to '1'.
#B7 = #80 + #37 = P
#C2 = #80 + #42 = X
#C7 = #80 + #47 = @
#C8 = #80 + #48 = :
#C9 = #80 + #49 = Return
#E1 = #80 + #61 = Z
#E8 = #80 + #68 = /
Do those match?
Postby oss003 » Wed May 31, 2017 6:11 pm
Yep, found it also:
#B7 = P
#C2 = X
#C7 = @
#C8 = *
#C9 = RET
#E1 = Z
#E8 = ?
Damn ... you're fast ........ :shock:
Thanks .... =D>
Postby tricky » Wed May 31, 2017 8:32 pm
Since DDR is set to rwwwwwww, the top bit is not used, also, seems to be a bit of a slow way to also return the result in N.
Postby oss003 » Wed May 31, 2017 8:53 pm
The top bit is used as checkbit, &FE4F reads &80 back if the key is pressed.
Postby tricky » Wed May 31, 2017 9:44 pm
I meant the top bits that are written.
