It is currently Mon Oct 20, 2014 4:35 pm
 Page 1 of 1 [ 13 posts ]
Author Message
 Post subject: The Quill
PostPosted: Tue Feb 06, 2007 7:34 pm
For the electron and BBC I found The Quill.
The application to write text adventures.
I got the electron version working with ElectrEm, but I cannot save on tape images with ElectrEm (or am I doing something wrong?)
The disc image from the BBC page says it's a disk version, but I think it is a tape version aswell. (this BBC version works also in ElectrEM, even when I transfer the disc image to ADFS E00)
Reading the manual, it says that the disc version gives the possibility to do some *commands, and I cannot find this in the menu.
And I also recognized that tis version switches to tape when saving the adventure.
Is there someone who can help me out?
I would like to have a version on disc, so I can save my adventures directly to disc. Does anyone have a real disc version?
Or can somebody tweek the tape version, so the save command does not go to tape?
Hope to find some answers
Koen
Offline
 Profile
 Post subject: Re: The Quill
PostPosted: Wed Feb 07, 2007 10:09 am
yo Koen
where can i get it, so can give a bash 4u :wink:
ow, found in the search 8)
_________________
Offline
 Profile
 Post subject:
PostPosted: Wed Feb 07, 2007 6:05 pm
You can find it at stairway to hell's site.
under BBC then disc images -> index filename -> thequill-e00.zip
The link of the zip is (i think) http://www.stairwaytohell.com/bbc/archive/diskimages/Gilsoft/TheQuill-E00.zip
great if you can do something.
Maybee stairway to hell would like to have a copy too. Then they have a disc image that works like a disc image and not switches back to tape.
cheers
Koen.
Offline
 Profile
 Post subject:
PostPosted: Wed Feb 07, 2007 6:09 pm
got em now, in the search (whats new, on right) :D
will have a look tonight, if got time, and up/l if i get it to work :wink:
_________________
Offline
 Profile
 Post subject:
PostPosted: Wed Feb 07, 2007 7:16 pm
Thats great!!!
Can't wait to check the forum again
cheers
koen
Offline
 Profile
 Post subject:
PostPosted: Thu Feb 08, 2007 11:29 am
nothing stood out :cry:
All i can suggest is to use BeebEm35 in Master mode (hardware-bbc model -master128 (to get E00 page)), and use save state. or can use the tape control part (comms-tapeControl)to make a .uef tape image of your saved adventure :wink:
_________________
Offline
 Profile
 Post subject:
PostPosted: Thu Feb 08, 2007 4:31 pm
Thanks for trying.
I thought it would be difficult.
It's a lot of assembly code. And I know things in Basic, but not in assembly.
If anyone else has a solution It would be great.
For now I'll use BeebEm to save to tape images.
Hope saving to tape images will work soon on ElectrEm as well.
Koen
Offline
 Profile
 Post subject:
PostPosted: Thu Feb 08, 2007 5:38 pm
I had a quick look too. I couldn't see any easy way of changing it to save to disc and I don't fancy sifting through 10k of machine code (maybe if I ever finish my 6502 (dis)assembler program)! :shock:
All I can suggest is to create a tape image of your saved game and then transfer it to disc. That may work, but it might switch back to tape again if you try and load or save a game during play.
Kind regards,
Francis.
_________________
Dreamland Fantasy Studios
http://www.dfstudios.co.uk
Offline
 Profile
 Post subject:
PostPosted: Thu Feb 08, 2007 9:18 pm
To get the program to load/save to disc, do the following :
*LOAD QL-MC
?&2985=0
*SAVE QL-MC E00 +29AC
Please backup the disc first in case it goes wrong but it works for me !
Jon.
Offline
 Profile
 Post subject:
PostPosted: Fri Feb 09, 2007 7:06 pm
Grand Jon!
It works fine, even when I have created a finl adventure. So that you can save the game on disc during game play. Great!
Does this code line also work on other adventures/games etc?
Koen
Offline
 Profile
 Post subject:
PostPosted: Fri Feb 09, 2007 7:35 pm
No, it just patches the Quill program to disable the *TAPE command.
For the technically minded amongst you, it patches a *FX &8C to *FX 0 thereby disabling the request to select the tape filing system.
Jon.
Offline
 Profile
 Post subject:
PostPosted: Fri Feb 09, 2007 10:32 pm
It's so simple when you know how. :roll:
Kind regards,
Francis.
_________________
Offline
 Profile
PostPosted: Mon Dec 23, 2013 12:35 am
Hello. Another long-time Beeb fan here -- though I don't have the same level of expertise and knowledge as people on this forum, whom I'm in complete awe of, frankly.
I just wanted to quickly de-lurk and mention some Quill-related shenanigans I've been getting up to. Apologies if this is old/dull news.
Using the diskified version of The Quill from StairwayToHell in Mac BeebEm (in Master 128 mode with &E00 DFS), together with the patch mentioned earlier in this thread that allows saving to disk, I've typed in the example game from the Beeb/Electron Quill manual. Disk image attached.
I discovered that there's a weird bug in the Quill engine: whenever an object is DESTROYed, the carried-objects counter is decremented, regardless of whether the player had been carrying the object or not -- with interesting results, the main one being that it lets the player get around the inventory limit set by the Objects Conveyable variable.
Anyway, I just thought this might be mildly curious/interesting to someone other than me. Apologies if it wasn't and/or if I shouldn't be bumping old forum threads.
-- lurkio, a.k.a. ahope1
File comment: Disk image containing tutorial game from Quill manual, plus Quill database file, plus savegame.
quilltutorialgame.zip [4.33 KiB]
Downloaded 17 times
_________________
Alien Jailbreak (2014): a new text adventure for the Beeb
Let's play Suds (1987), a Quill text adventure
Let's play L – A Mathemagical Adventure (1984)
Offline
 Profile
Display posts from previous:  Sort by
You cannot post new topics in this forum
You cannot reply to topics in this forum
You cannot edit your posts in this forum
You cannot delete your posts in this forum
You cannot post attachments in this forum
Search for:
Jump to:
phpBB skin developed by: John Olson
Powered by phpBB® Forum Software © phpBB Group
