Robico Banjax Cheat?
b_b_c_m_i_c_r_o_2
Postby b_b_c_m_i_c_r_o_2 » Mon Jun 27, 2016 11:50 am
Do you know of any Banjax cheats?
I used the Beebem debugger to discover one to stop the creepy-crawlies killing Banjax when they collide. I just need to fine-tune it as it was also stopping me picking up the bag and subsequent items. I need to fine tune it so that it treats the crawlies as inocuous objects. It looks like all that is needed is a couple of bytes of the file Banjax3 need changing.
billcarr2005
Re: Robico Banjax Cheat?
Postby billcarr2005 » Mon Jun 27, 2016 5:38 pm
C 1FB1 0
b_b_c_m_i_c_r_o_2
Postby b_b_c_m_i_c_r_o_2 » Mon Jun 27, 2016 6:12 pm
I came up with 1fd9 = 32 :) (which turns 1fd8 to BEQ 200C instead of BEQ 1FAD)
Last edited by b_b_c_m_i_c_r_o_2 on Mon Jun 27, 2016 6:17 pm, edited 1 time in total.
b_b_c_m_i_c_r_o_2
Postby b_b_c_m_i_c_r_o_2 » Mon Jun 27, 2016 6:16 pm
pasted the default banjax code path when collide with a monster....
b_b_c_m_i_c_r_o_2
Postby b_b_c_m_i_c_r_o_2 » Tue Jun 28, 2016 8:59 am
billcarr2005 wrote:
C 1FB1 0
Thanks! - you got that one quick! or was it one you already had in your back pocket?
b_b_c_m_i_c_r_o_2
Postby b_b_c_m_i_c_r_o_2 » Sun Jan 15, 2017 5:52 pm
I found one problem.....if you get caught in a corner with one or more monsters it can prevent you from actually moving and you are stuck there forever...............as my niece and nephew found out!
I suspect that would be more tricky to work round... I am not sure how the collision detection routine decides the difference between a wall and a monster...
Postby lurkio » Sun Jan 15, 2017 6:08 pm
b_b_c_m_i_c_r_o_2 wrote:
billcarr2005 wrote:
C 1FB1 0
More generally, how does anyone know anything about the BeebEm debugger at all? How does it work? What are the commands you can use in it?
There's apparently no documentation for it -- or at least no one seemed to have any when I asked the question in 2014.
So how are you supposed to come up with arcane incantations like "C 1FB1 0"? Do you have to be psychic?!
billcarr2005
Postby billcarr2005 » Sun Jan 15, 2017 11:09 pm
? brings up the debugger help
- BeebEm debugger help -
  Parameters in [] are optional. 'p' can be specified in some commands
  to specify parasite processor. Words preceded with a . will be
  interpreted as labels and may be used in place of addresses.
  bp start[-end] [name]
    Sets/Clears a breakpoint or break range.
  labels [filename]
    Loads labels from VICE file, or display known labels.
  help [command/addr]
    Displays help for the specified command or address.
  set host/parasite/rom/os/endian/breakpoint/decimal/brk on/off
    Turns various UI checkboxes on or off.
  next [count]
    Execute the specified number instructions, default 1.
  peek [p] [start] [count]
    Dumps memory to console.
  code [p] [start] [count]
    Dissassembles specified range.
  watch [p] addr [b/w/d] [name]
    Sets/Clears a byte/word/dword watch at addr.
  state v/u/s/t/m/r
    Displays state of Video/UserVIA/SysVIA/Tube/Memory/Roms.
  save [count] file
    Writes console lines to file.
  poke [p] start byte [byte...]
    Write bytes to memory.
  goto [p] addr
    Jump to address.
  file r/w addr [count] filename
    Read/Write memory at address from/to file.
  echo string
    Write string to console.
  script [filename]
    Executes a debugger script.
Command aliases:
      bp: b, breakpoint
  labels: l
    help: ?, q
    next: n
    peek: m
    code: d
   watch: e
   state: s
    save: w
    poke: c
    goto: g
    file: f
    echo: !
mostly all that's required is "d" to disassemble and "m" to dump memory :)
"c" changes the memory at location to whichever value
b_b_c_m_i_c_r_o_2
Postby b_b_c_m_i_c_r_o_2 » Sat Jan 21, 2017 10:37 am
Looking at how the game plays... the monsters are able to pass through each other unhindered but that is not the case with the Banjax character. I think that is the bit to target if I can make it so the monsters think Banjax is another monster that should work.
b_b_c_m_i_c_r_o_2
Postby b_b_c_m_i_c_r_o_2 » Sat Jan 28, 2017 10:11 am
For the bears movement, I think there are two collisions mechanisms. The one that sometimes prevents you passing through monsters is because the game wont let you move in a direction where the screen just outside the extent of the sprite in that direction isn't the same colour as the background. I changed the flying creature into a line of red and I can get the issue where the bear can't turn right.
Although saying that monsters can pass through each other without difficulty
Also I dont think the monsters have collision detection with the walls - I think they are programmed not to travel further than where the fences are (or might me). i.e. the monsters do not travel into that gap in the fence that the bear can get into.
Banjax collision
eelco
Postby eelco » Mon Jan 30, 2017 10:09 pm
I remember there was a really easy way to cheat. The monsters appear randomly in the screens every time you run Banjax, so I figured that there must be some random number generator involved. When looking at the loader (called BANJAX, part BASIC part machinecode) you can see that random values are put in locations &0080-&0087:
  10REM
     "BANJAX" By Robert O'Leary
              (c) 1985
   20MODE1:VDU23;8202;0;0;0;:FORI%=0TO&3
10STEP4:I%!&1100=I%!TOP:NEXT
   30*FX200,3
   40*FX4,1
   50*FX210,0
   60ENVELOPE1,2,30,0,-30,1,1,1,110,-3,-
3,-3,120,100
   70ENVELOPE2,1,0,0,0,0,0,0,110,-5,-5,-
5,102,90
   80ENVELOPE3,128,-1,-1,-1,18,18,18,127
,0,-1,-2,126,100
   90ENVELOPE4,1,0,0,0,0,0,0,126,-1,-1,-
1,126,80
  110!&80=RND:!&84=RND:CALL&1100
Now, if you replace line 110 with:
  110!&80=0:!&84=0:CALL&1100
...no monsters will appear whatsoever :)
My Acorn related files are located at:
https://acorn.huininga.nl/
b_b_c_m_i_c_r_o_2
Postby b_b_c_m_i_c_r_o_2 » Sun Feb 19, 2017 5:15 pm
thanks!
b_b_c_m_i_c_r_o_2
Postby b_b_c_m_i_c_r_o_2 » Fri Mar 31, 2017 12:50 pm
I just worked out the game is a bit boring and you can't do anything until you get the bag.
eelco
Postby eelco » Mon Apr 10, 2017 11:16 am
A map and the solution can be found here: https://acorn.huininga.nl/pub/docs/game ... re/Banjax/
Without monsters the game is indeed a bit boring, but you'll be able to finish it in 15 mins, if you know your way around
streaks
Postby streaks » Sun Jul 23, 2017 3:18 pm
I did that line 110 thing, and I just get an error. Sometimes it's just "at line 110" and sometimes it's "ONOSCLILEN ONOSCLILEN ONOSCLILEN at line 110".
Am I supposed to save the BANJAX file in a way other than SAVE "BANJAX" since it's part machinecode?
I tried manually executing the lines in LOAD, then loading BANJAX and changing line 110 and typing RUN, and the screen just went black.
Oh, my God, this is so exhausting. Beeb logic is a f'ing mystery to me. I've been at this for ages.
streaksy (at) gmail (dot) com
Postby lurkio » Sun Jul 23, 2017 4:15 pm
streaks wrote:I did that line 110 thing, and I just get an error. Sometimes it's just "at line 110" and sometimes it's "ONOSCLILEN ONOSCLILEN ONOSCLILEN at line 110". Am I supposed to save the BANJAX file in a way other than SAVE "BANJAX" since it's part machinecode? I tried manually executing the lines in LOAD, then loading BANJAX and changing line 110 and typing RUN, and the screen just went black. Oh, my God, this is so exhausting. Beeb logic is a f'ing mystery to me. I've been at this for ages.
Here's the disc-image pre-edited with eelco's cheat:
:idea:
streaks
Postby streaks » Sun Jul 23, 2017 4:40 pm
    Disc012-Banjax.ssd.zip
:idea:
Thaaaaaank you. But for the sake of learning... what was I doing wrong? Is it easy to explain? ;/
Postby lurkio » Sun Jul 23, 2017 4:45 pm
streaks wrote:But for the sake of learning... what was I doing wrong?
No idea! I just downloaded the disc-image from bbcmicro.co.uk and the used a hex-editor app on my laptop to change two bytes in the .SSD file. The two bytes I changed were the two bytes that each represented the tokenised form of the BASIC keyword RND, on line 110: I changed each of the two bytes to zero.
:idea:
EDIT: I've just realised I didn't change the two values to zero -- I actually changed them to &30 (the ASCII value of the character "0")!
streaks
Postby streaks » Sun Jul 23, 2017 4:46 pm
Oh, I didn't try editing the file outside of BeebEm. Cheers though.
eelco
Postby eelco » Mon Aug 14, 2017 7:49 am
streaks wrote:Thaaaaaank you. But for the sake of learning... what was I doing wrong? Is it easy to explain? ;/
Ahh of course.. The Banjax loader is part BASIC and part Machine Code. When you replace line 80, the BASIC language somehow changes the TOP variable, which will change the start address of the machine code part.
If PAGE is &1900, this might work:
PAGE=&1900
LOAD"BANJAX"
?&1AF7=ASC"0"
?&1AFE=ASC"0"
LIST (just to check if we haven't broken the BASIC part)
RUN
streaks
Postby streaks » Mon Aug 14, 2017 7:51 am
All these years later and "machine-code" isn't much less mysterious. :D Thanks.
PS Your repository site looks interesting...
